You could try Mechanism Wizard to solve follower joint on this kind of closed loop system. Add-on can be found here:
I tested it on your model and it works if you first make rotational joints parallel. Mech wizard is little picky about that. Here’s a video on how I aligned joints and then used MW to solve followers:
