Hi all,
I am looking for a reference document or tutorial explaining the control of the MiR1000 EU Pallet Lift.
I need to control the AGV only by passing values to its control signals without using any process modelling within Visual Components.
From what I understand by just looking into the component structure there are just two signals:
- Task : String
… which is used to describe the next task to be added to a task list - Trigger: Boolean
… which I assume is used just for a confirmation for the task above to be added in the list
so I should be able to assign a task to the agv by
first setting the “Task” signal to a proper value
and then set the “Trigger”
but I don’t know the list of appropriate tasks, how you define the locations of each task etc:
by looking the python code I see some values for task (just searching for task[0]=) and this seems to include
task[0] == “Wait”
task[0] == “Move”
task[0] == “Need”
task[0] == “HumanProcess”
task[0] == “Feed”
task[0] == “Transport”
I am not sure if this is all or how you are supposed to use them
Also I see in the component structure some properties such as
Path_Points
Path_Comps
etc
which I understand are defining the paths between the different task locations
but these are initially unpopulated and I assume are populated when connecting the component to other components in a process
but
How should I go about in defining the paths, tasks and control of the AGV WITHOUT process flow functionality of VC (just using signals)?
