hi~
https://forum.visualcomponents.com/forums/topic/blender-2-80-addon/
I am wondering how to apply blender add-on.
- Install Blender 2.8.
- Install Blenderer2 zip
However, the add-on did not run.
How to add add-ons?
info.pptx (519 KB)
hi~
How to add add-ons?
info.pptx (519 KB)
You are running a Delfoi application. Is there a Delfoi folder under Documents.
Something like this:
C:\Users%USERNAME%\Documents\Delfoi\4.1\My Commands
If yes, try to add the addon under that folder.
Edon added.
However, an error like the picture occurs.
C:\Program Files\Blender Foundation\Blender
(Blender.exe is installed in the C: \ Program Files \ Blender Foundation \ Blender \ Blender.exe path.)
The picture is cut. The error message is:
File “file:///C:\Users\이재경\Documents\Delfoi\4.1\My Commands\Blenderer2_0_1__2019_09_19\Blenderer2_2019_09_19\Blenderer.py::”, line 13, in <module>
ImportError: No module named export_from_vc
hi eme,
Is there a video to show how to manage a well-rendered picture using this add-on just like the one you posted , i have no clue how to render it nicely ,i guess many fellows share the same problem. Thanks in advance.
I’m not sure what’s wrong with your setup. I don’t have a delfoi application at hand so I can’t test it. Could you ask from Delfoi support?
Hello!
Is there a way to update the add ons?
Or should I uninstall or reinstall?
Thanks
The only way to update the addon currently is to delete the old addon files and download the new version.
Hi @EmmaOD
You can update addon installations with the Addon Store.
The current version does however not detect existing Python addon installations.
So just remove the Blenderer folder from your My Commands folder:
C:/Users/(Your user)/Documents/Visual Components/(Version)/My Commands
After that you can install it via Addon Store.
From there on you will be able to easily upgrade to future Blenderer versions.
