1 - Look disussion here: Export, import, Unity, Assembly, hierarchy, simulation, seperation - #4 by captain_feature
2 - Jes that makes no difference.
Hi emetirus
I have a main problem with Blender and thats when I click on render animation each time something strange happens. Mostly it stops the rendering in the first two or three seconds and gives an output video.
My computer specification is good and is corei710700, Ram32GB, GPU1650.
The first time I tried it, the rendering process took about an hour and gave 27seconds animation(the whole process should take 1minute). but know the rendering process finishes in the first 5 seconds and just gives less than 5 seconds animations and sometimes even less.
How should i solve this problem?
Thanks
Hi there,
I also have EXCEPTION_ACCESS_VIOLATION error but I donāt use any monitor. Also, no further message appears explaining an error, it just closes the rendering. Any idea of what it can be due to?
Thanks in advance,
Hey there again,
After making many tests with my layout I see that the blender addon crashes whenever I include any ROBOT from the eCatalogue. Does someone know how to solve this?
I appreciate the help.
Is it possible to have dynamic light in a model. For example changing the color, turning a light on/off, changing the strength during the runtime of a simulation?
It seems to work in VC itself, but when rendering in blender, the light does not change.
Hi, i already tried to solve this problem and asked about it. For this version its not possible. Here is link to my question and responses: Light switching in blender video
Hi, Are you sure the animation start and end properties didn\t change. It sounds weird that it doesn\t render the whole recorded animation but still outputs a video. If the rendering crashes then you wouldnāt get a video at all.
Does this problem happen with any layout or only with a specific layout? If you canāt get it going, please share the layout and screenshots of your blender addon settings. Also let us know which blender version you are running.
Sorry for the long waiting time.
If you are having same issue as line_out then it is most probably a graphics card issue. Addind a robot in scene causing a crash alos hints that way as robots are rendered with more complex shaders. You can disable this feature on Materials tab by setting Robot materials to default and then test again.
If it is a graphic card issue, itās real hard to help you. I would suggest upgrading/downgrading your driver or testing another version of Blender.
Sorry, which version you refer to?
Iām not sure about the version. I asked VC support for help and they sent me a previous version:
Blenderer2_0_1__2019_09_19
Regards,
This is more of a Blender question, but does anyone have a solution for updating all object animations in Blender while keeping the meshes as they are?
The reason for my question is that for bigger projects itās often time consuming to re-render the entire simulation. Also, I often do some material tweaking etc. in Blender so I would really like to keep as much as possible of the scene and just update the animations.
For armature animations it seems fairly possible to link animation data/copy keyframes between objects, but for node animations I canāt really come up with a solution. Also, finding a way to batch replace is essential, since manual replacement is no option.
New version 2.2.0 released just now. Find the download link in the original post. At the end of the original post thereās a detailed list of whatās new.
It can do this:
Did you find any solution to this problem⦠I have just the same issue.
No, but I found the problem. I am a Delfoi (app on top of VC) user and it seems that there is a Delfoi bug in the action panel, that causes this. The issue has been reported to Delfoi, but I do not know if it has been fixed yet.
Okay! Iām also using DelfoiArc addon. So I have first installed first native VC Premium 4.2 and then Delfoi addon⦠I have some connections to Delfoi. I can ask if they are about to do something to this issue.
It looks like version 4.4 is coming soon, isnāt it?
@okekeoo
There might. Typically software houses are working hard to release a new version. I also edited the the release notes in the original post a little
