Is it possible to model vibration behavior in visual components. I am logging the data from vibration sensor which is connected to an arduino and feeding it into matlab. I understand that i can expose these values into OPC UA server and from there i can map them in Visual Components. My question is how do i create a vibration behavior in Visual Components.
Hey, Ishitagarg this thread maybe off some use to you
you can connect a signal to the object you want to vibrate. and give it a motion through that connection between a robot and that object. be sure about the movement. it has to be small movements. after all these, you can set that signal true and false repeatly. so it will look like vibrating.
