vcSelectionManager doesn't update Robot
I’ve written a pythonscript where I select a Lin- or PTP-Motionstatement over the vcSelectionManger.setSelection(statement). → Works well, the selection is done! :slight_smile:
The problem is that the robot doesn’t update it’s position like I would select the statement in the UI.
Please could anyone tell me how to update the robot so it behaves like an UI-selection of an statement?
Thx & Regards
app = getApplication()
sm = app.SelectionManager
robot = getRobot(comp)
statement = robot.Executor.Program.MainRoutine.Statements[0]
sm.setSelection(statement)
motionTarget = robot.Controller.createTarget()
motionTarget.Target = statement.Positions[0].PositionInReference
robot.Controller.moveImmediate(motionTarget)
I think you also need to handle vcMotionTarget’s base, tool, … etc.
thx for your answer. :slight_smile:
Unfortunately I think you are rigth, in this form the robot do some other things… :wink:
My target is that the robot behaves with the code like I select an statement in the userinterface (programTab…).
If you want to do UI things then just use the .NET API instead.
jes normally I would, but in this case it would bei great If someone would know the netCommand for pythonApi which updates everything that the magic happens… :smiley:
Thx & Regards
now I testet the same thin over .NET API (ISelectionManager.SetSelection(statement, false)) and get the same result… → The robot don’t update its position like an userAction/userSelection does! :frowning:
What is the thing I have to do?
Thx & Regards
