Hey community,
It seems singularities can be display in the output terminal by marking this 2 settings:
Program > Limits
Singularity
Message panel output
Additionnaly do you have any trick to stop the simulation when a singularity occurs ?
Thank you in advance.
Cheers.
TSy
2
.NET API has this event that should include singularities if those tests are enabled.
keke
3
If you have also “Stop at Limits” checked then the simulation should stop also when singularity occurs.
works! thank you @keke
(cool avatar btw)
