i was wondering if there is any way to and some sort of quality checking camera, that would take a photo inside the simulation and send that photo to a computer screen. there is a dummy version of this camera but i was wondering if there is any way of making one that actually works?
This is a quick easy example to simulate computer vision in VC. Since observer view and camera view share same window, so the downside is that you have to keep same observer view, the upside is that the code is 36 lines and easy to use, you can adjust parameters of vcView object as you wish, the script is in “Quality check camera” component.
Observer view: View (Any location as you wish)
Camera view: TakeImage (Any location as you wish)
Start simulation to take images automatically, quality check camera’s signal is connected with conveyor sensor’s signal, new image will be saved when workpiece passes.
- TakeImage: Take image manually
- ImageFolder: This indicates the saved images folder path, not file path, so you need to fill it manually, don’t forget to add slash at the end. (Update: Added check slash function)
- OpenFolder: Open saved images folder
TakeImage.vcmx (1.3 MB)
Where can I find saved images?
Select quality check camera component. There is ImageFolder, this indicates the folder location, not file location, so you need to fill it manually, something like “D:\CV\”, remember always add slash at the end.
Very good, thank you
is there any way to display these images inside the simulation as they are being captured? on a computer screen or something
Thank you for sharing, it has been particularly helpful to me, but I have a question I would like to ask you. During runtime, why does the ‘Index out of bounds’ error occur? What are the solutions to fix it?
Fixed, works for 4.10
TakeImage_v2.1.vcmx (1.2 MB)
Wow, you are really nice, thank you very much for your reply, it is a great help to me.
Hi, I’m trying to do this job, but I ran into a problem. When running the script, the following error is displayed. Can you tell me how to fix it and do I need to create something in the camera object besides a signal and a script?
Try
def OnTakeImage(arg = None):
If this is not event, you could just remove arg
def OnTakeImage():
After launching, I get the following error:
File “camera::PythonScript”, line 29, in
File “camera::PythonScript”, line 14, in OnTakeImage
File “camera::PythonScript”, line 21, in TakeOneImage
File “camera::PythonScript”, line 17, in checkSlash
NameError: The ‘ImageFolder’ attribute or method was not found.
Use the sample layout, replace the geometry would be faster.
I am using the Russian equivalent of Visual Components, which does not support this project format. I’ve dealt with the past mistakes, but now this appears.
