Hi guys,
I can’t program this gripper. The gripper center point is set strangely. Can this be changed in the program or does the CAD file have to be revised?
Here is the CAD file of the gripper:
bg100_asm.stp (3.3 MB)
Many thanks for your help
Hi guys,
Yes you can adjust center point easily just by using these two buttons.
Many Thanks. But now I have another problem. The gripper always turns in the wrong direction. how can I set this correctly?
Use move origin and in right just change rotation by 180 in requiered axis
bg100_asm.vcmx (1.2 MB)
Thank you very much. I tried it myself. I have a question. how did you do that? How do I Programm those two components, so they stay together? As you can see in the Picture I added, the two components do not stay together.
You can learn this
