Thank you I also tryied this scenario, but it didn’t work for me. Maybe wrong filtering…?
If I set any one of the filtering on one sink process, part went only to the second one…?
Should I use 1. Reserve Product, 2. Property Condition, 3. TransportIn condition?
You can create 2 flow groups, each goes to one one sink. Then in Process #2 you can use the change product type to switch the product toanoter that is in a different flow group.
For this use case it is not even necessary to use filtering. In case you want to use these filters, I personally use the option 3 from your picture, so in TI statement.
