Dear community,
I’m opening once again topic for material distribution based on ProductID.
I saw older similar posts like:
but, I’m still unable to build it.
I have hundreds of pallets comming to repacking area (therefore I cannot create separate flows). Pallets will be dropped to the buffer and if ProductID will be set to “single box repack” Pallet should go to process 1 and if ProductID will be “pallet repack” it must go to process 2.
I’m also unable to filter accepted products in each process, because as I mentioned, I have hunderds of products coming through.
Thank you in advance for any advices.
