This addon is used to copy a process routine from a component into other components.
You can choose to paste it into all processes of the layout with the same name, or select the components in which it should be added or updated.
It is usefull if you want to update a lot of parallel processes :
Extract the zip file to the My Command folder: C:\Users\Documents\Visual Components\My Commands\Python 2
ProcessCopyPaste.zip (5.0 KB)
(This AddOn has only been tested in the Visual Components 4.10 version, it is possible that it doesn’t work for previous versions)
