I made my own geometry. This geometry must pick and place products. How can I pick up the product with the ‘‘gripper’’? Is it actually possible? See image.
Let me know!
Let me know!
You could use the Grasp wizard (Grasp Wizard 2 (Professional)) to add the gripper functionalities. Then, it’s easy to send a signal to grip or release the part.
Thank you!
Cleary am missing something. Otherwise it while be to easy. Can you point out how i can pick up the can?
Replace GraspSignal = True with this:
grasp_signal = comp.findBehaviour("GraspSignal")
grasp_signal.signal(True)
Hello Este, I have the same issue, And when using this code, The coponent does not attach
