Grasp Wizard 2 (Professional)
Hello all,
I have been using the original Grasp Action Wizard (Professional) , and over time, I added some additional functionalities.
As with the original addon, you can add grasping and releasing functionalities to any component.
This updated grasp wizard can trigger the grasping signal automatically based on collisions and servo motions. The grasping logic has also been updated for new functionalities like process modeling assemblies.
Usage
Connect and send a True signal to GraspSignal for grasping and a False for releasing. Check TCPFrameLocation and DetectionVolumeSize if components are not picked up. Grasped components are attached (and following) the Node/Link given when applying the wizard.
Additionally, you can select a servo joint that will trigger the GraspSignal automatically when the servo moves or changes direction past the threshold.
13.06.24 Update: Small improvements and bug fixes.
22.09.25 Update: Fixed an issue with the default detection volume size.
16.10.2025 Update: Fixed Path folder handling for foreign letters.
Installation
Requires access to Modeling tab (Professional or Premium license)
Download the addon package:
GraspWizard2.zip (16.9 KB)
Like usual: Unzip the file to your ā€œMy Commandsā€ and re-launch. E.g C:\Users%username%\Documents\Visual Components\4.8\My Commands
or
C:\Users%username%\Documents\Visual Components\4.10\My Commands\Python 2\
thank you.
I was looking for a feature like this, thank you for your effort.
Hello, Esta.why can I grasping but can’t releasing. :sweat_smile:
What results do you get If you enable the message prints? And have you tried changing the gravity direction value?
Hello Esta,
A few days ago i installed the grasp Wizard 2. after assinging the true signal it did work.
After saving the program and reopening it, i get two messages and can’t get the grasp function to work again.
Could you give me a tip as where to look for this problem.
Lift met Grasp werken 20240526.vcmx (122.8 KB)
Looks like you have renamed the signal name. You can modify the Grasp script around lines 680 to use the new behavior names and then it should work again.
Instead of detection_node.Name, replace these lines with the exact name of the behaviours you want to use.
Hello, Thanks a lot. It works again. and it keep’s working after i saved and restarted the program.
Hello everyone,
I’ve been using the default Grab Wizard so far.
The expert version is more utilized, so I’m going to try using it as the appropriate Add-on.
Unlike the Grab Wizard I used before, many function have been added, so are there any manuals or instructions on what each function means and how to use it?
hello @Este
Is there a way to change and fix the ā€œDetectionVolumeSizeā€?
For example, if I change the DetectionVolumeSize to X:70 Y:40 Z:20 during simulation, it works with the modified values.
However, after saving the file and reopening it, the DetectionVolumeSize returns to its default value of X:5 Y:5 Z:5.
화멓 캔처 2025-09-19 183549
Thanks for pointign this out. This issue should now be fixed. Please downlaod the updated GraspWizard2 from the original post.
thank you so much :slight_smile:
@Este
Hello, I’ve been using the Wizard you created and it has been very helpful. Thank you.
However, I’ve encountered an issue while using it, so I’d like to ask for your advice.
When I run the sample project ā€œGrasp Wizar2_Errorā€,
the Feeder produces a Block Geo stacked in three layers.
But as soon as the Grasp Signal turns ON and it tries to grasp the three-layer Block Geo,
it changes from three layers to a single layer, and the Block Geo is destroyed.
The Block Geo was created as an Assembly in [Process] - [Product] - [Product Type Editor].
This issue did not occur in the previous version, Grasp Wizard1.
Grasp Wizar2_Error.vcmx (232.2 KB)
Hello @LEEYONGKOOK,
Set GraspIncludeEmptyAssemblies as ā€œYesā€. In the layout, the grasping mechanism forcibly grabs the only product in Step #1 out from the assembly, so steps under Step #1 were deleted.
By using GraspIncludeEmptyAssemblies = ā€œYesā€, the mechanism grasps the entire assembly instead of just the one part it detects.
I’m doing what you told me, so it’s working well.
Thank you so much for your response. :+1:
Hello @Este
I know you’ve been using this edon well, and I’ve carried out a reinstallation of the edon while updating to the latest version of VC 4.10.
As I tried to use it after proceeding with the reinstallation, an error occurred as shown in the attached picture.
I don’t think I can read the path name because the path contains Korean, do you know how to solve the problem?
Ok there is a problem with handling foreign characters in the addon folder path. I made some changes. Please download the new version and test if it works now.
Thank you, and I will proceed with the reinstallation!
Hello @Este
I’m having a problem where, when I duplicate a component using the ā€œPatternā€ feature and then grab it with the GraspTool, it never grabs a single object, but always two – even though MultiGrasp is disabled. Do you have any ideas about this?
Aside from that, I’m very happy with the add-on. Very nice work.
Sounds odd. With multigrasp disabled it should only grasp one item. You could also check that your detection volume size is not too large?
I already reduced the VolumeSize to 1, 1, 1. Still happens.
