New to Visual Components – looking for a structured learning path for welding robot simulation
Hi everyone,
I’m completely new to Visual Components. My company has a license, and we use a welding robot on the shop floor — I’d like to build a solid foundation in the software rather than just picking up scattered bits and pieces.
I’ve gone through quite a few of the official YouTube tutorials and I’m practicing along with them, but honestly I’m starting to feel lost — there’s so much content that it’s hard to know what order to learn things in, or what’s actually foundational versus more advanced/niche.
Could anyone who’s been through this point me toward: a recommended learning path/order for a true beginner (not just a list of individual videos); which Academy courses or docs are the “must-know basics” before moving into robot programming; and any tips specific to setting up and programming welding robot simulations.
Any roadmap, checklist, or structure you can share would be hugely appreciated. Thanks in advance!
This is only my personal opinion. For VC, it is more suitable for simulation of production lines. What I mean is that it is generally used for simulation of external equipment + robots.
I’m not sure whether users of welding robots need parts other than the robot itself. If so, here is my personal opinion:
  1. I would lean toward first roughly learning the Process part. At least I need to know how to quickly build a movable scene in VC.
  2. After an initial understanding, I would start learning the modeling module. This is based on the experience of my seniors. In fact, I still think so now. The modeling module takes up most of the time spent using VC. I would first learn how to make my own custom components (such as the custom feeder in the academy).
  3. After learning how to make my own custom components, I would start learning the specific modules within modeling in detail. In fact, for me, the ones I use most are path, python script, sensor, and feature.
  4. Based on the previous step, when learning Python script, I would come into contact with many VC APIs and more knowledge, such as how to make my own Python plugin and how to get used to looking up the VC Helper.
  5. Later on, I would find that the Python API is no longer enough, and I would start learning the C#/C++ APIs further. However, this is a fork in the road. In fact, for you, you should start learning robot OLP.
As for the robot OLP part, honestly speaking, the tutorials provided by VC are somewhat scarce. Many times you need to explore on your own or seek help from local suppliers.
This is a rough summary of my learning experience, but my job is more focused on simulation verification with robot OLP as a sideline, so you may need to pick and choose the parts you need.
Hi @Omri.Abudy, I started learning Visual Components from zero in March and have basically been using it as my main daily tool since then, so I’m 5 months in and have accumulated 100s of hours with it at this point.
I agree with what @BAD said that the main strength of VC is indeed process modelling and that’s what you should focus on (although lately it seems they are also pushing the OLP part a lot). So building out different production line logic, material flow, processes, using different resources, including also robots and welding robots - focusing on the Process tab basically.
However, I don’t think you need to initially get very deep into custom modelling, because another strong point of VC is the included catalogue with thousands of available components and it gets you quite far without doing any custom modelling yourself. So this part is advanced - 95% of times the catalogue (and the example layouts) already has the part/solution you need.
The real learning comes from trying to model/simulate real world situations, because there is definitely a big gap between watching Academy videos and doing some tests and creating a real simulation. With real cases you will run into unexpected problems / seemingly random things will not work as you want - working through those issues (troubleshooting, posting on the forum, rewatching and re-rewatching academy videos) will get you real understanding of the software bit by bit.
(When you try to model realistic situations, you will anyway eventually find that you need to apply some more ‘advanced’ solutions in some cases and that’s where you will start looking at things like py scripts, sensors, signals etc.)
So you should work on real/realistic cases as much as possible and maybe for you it makes sense focusing on welding related processes, so you can already include the OLP part with weldding robot cells in the flows.
…also having an actual welding robot available is a huge advantage. I experimented with OLP a bit, but I would say that just by itself it’s not very valuable - the real gap is 1) how easily can you get from the VC exported program to an actual working robot program and how much actual commissioning/adjustment do you need to do on the physical robot and 2) welding knowledge - correct speeds, feeds, welding parameters, angles for different welds. With a real robot you could work on the whole cycle from VC to real program, which might be very interesting.
Good luck!
Side question @BAD - where do you even find VC C#/C++ APIs for learning and development? I still don’t understand whether that’s a deprecated topic or not, also the help file only gives the Python api.
No, what I meant is not that the Python API is outdated, but that it may not be able to fully cover my needs. The Python API is a secondary use of the interfaces exposed to VC. In other words, for interfaces that have not been officially distributed, the Python API has difficulty calling them.
In such cases, I would consider using C# or C++, using lower-level APIs from lower-level code.
Regarding the use of the C# API, I initially learned from William’s video tutorials (William has stopped forum activities), but his tutorials should still be available in the academy, which taught me the most basic calling methods. Additionally, there are some scattered discussions in the forum that mention certain APIs. Of course, in my opinion, the most important thing is to first get used to using the Python API, and using the C# API is basically similar, except that you need to consider the syntax issues in C# (thanks to AI technology, I don’t need to spend much effort on this now).
I highly recommend TSy’s plugin here. With it, I no longer need to spend time searching for the classes and properties of specific targets, which is very helpful for development.
Hello @Omri.Abudy,
Have you already found the Academy learning path "Using Visual Components for Robot Offline Programming (OLP)? Using Visual Components for Robot Offline Programming (OLP)
It starts with introductory lessons for general UI controls and layout configuration, proceeds to basics of OLP, and finally into a 9-lesson package specialized for arc welding.
