Inspector 3.5 Beta for VC 5.1: Copilot Chat and AI-Assisted Editing
TL;DR: Inspector 3.5 beta adds an experimental Copilot chat directly inside Visual Components, new opt-in editing and automation capabilities, and a packaged Visual Components focused workspace for scripting and Python migration workflows.
Inspector 3.5 beta requires Visual Components 5.1.
Inspector 3.5 beta expands Inspector from a mostly read-oriented AI inspection bridge into a more complete AI-assisted workflow for Visual Components.
Main features in this beta:
- Copilot chat inside Visual Components with Ask mode for investigation and Edit mode for approved editing workflows
- Opt-in layout and component automation for larger tasks such as changing machine configuration, updating process settings, and saving revised layouts or components
- eCat catalog search and insertion for finding components and example layouts from the catalog of over 4000 models, then loading and positioning selected content
- Process Modeling troubleshooting support for diagnosing broken flows, transport issues, runtime state, and output errors
- Improved Python script workflows for exporting, editing, validating, importing, and migrating scripts from Python 2 to Python 3
- Packaged Copilot workspace with Visual Components specific guidance, Python API reference material, migration support, and helper tooling
Editing capabilities are not enabled silently. Inspector prompts user before allowing tools that can modify files or the live layout.
Example things to try in the beta:
Export the Python scripts from this layout, summarize what each one does, and prepare a migration plan for the Python 2 scripts.
Export the Python 3 script from the selected component, make [describe the script change], validate it, and import it back into the layout in this session.
Investigate why products are not reaching the selected machine, or why they arrive there but never leave. Use the current viewport and selection for context, then check process configuration, transport links, runtime state, and output errors before suggesting changes.
Test these process changes in this copied layout around the selected process or visible work cell: set the failure settings to [failure settings], update the process-time delay to [duration], try [transport link change], and save the result as a new layout version.
Search eCat for robot families suitable for [payload/reach/task], explain the most relevant manufacturer naming patterns you find, and suggest components or example layouts to try.
Build a simple test layout from eCat content for [process goal]: search for suitable components, insert them, position them, create the basic Process Modeling flow, and run a quick test.
More detailed guide: Inspector 3.5 beta user guide.pdf (159.8 KB)
Beta Installation
- Install the current Inspector add-on for Visual Components 5.1.
- Start Visual Components once so Inspector creates its settings, then close Visual Components.
- In File Explorer, open
shell:Personal (My Documents folder), then edit this file:
Visual Components\5.1\Inspector\Installer settings.json
- Change:
"ReleaseChannel": null
to:
"ReleaseChannel": "beta"
- Start Visual Components again and let Inspector install the beta update and Copilot workspace.
The first beta install can take several minutes because it downloads and extracts both the add-on update and the packaged workspace.
This is still a beta, and the Copilot chat integration is experimental. Please try it with copied layouts where possible and share feedback about installation, chat usability, edit-mode safety, script workflows, and Python 2 to Python 3 migration results.
PS: There likely won’t be any updates for about 3 months due to summer holiday season.
