I don’t know much about Inventor as a program, but if you could import the .stp file it exports into VC, then you could set up a PnP interface for it under the MODELING module, and connect it to the robot flange through the PnP interface, or let’s keep it simple, you could snap this component to the gripper jaws, and use the add-on to make it additionally bound to the robot flange, but doing so If you do this, you won’t be able to use the robot’s quick-change tool feature easily.
They should show how to model your own end effector and should also show how to use wizards to make this a bit faster if you do not want to do everything manually. I would still recommend to not use wizards if this is your first time modelling an end effector.
