This .NET plugin can record values being written to simulation through the Connectivity feature and then replay them into another simulation run without the external connection. It allows easier debugging of issues, non-realtime operations like recording or Blender animation export, and saving warmup sequences or demos with layouts to be used later.
Works with VC 4.4 and probably with VC 4.3. Install by copying the dll to your VC installation folder.
IO record and replay add-on.zip (14.8 KB)
Features:
- Records input values coming from Connectivity to simulation and can replay them back into the simulation later without the external connection.
- Replay uses simulation time scheduling so its accuracy doesn’t depend on playback speed or pauses.
- Inputs to record are automatically imported from active “Server to simulation” variable groups, and can be different for each recording.
- Multiple recordings can be taken and saved within the .vcmx file.
- Can record and replay all simulation variable types supported by the Connectivity feature. However, saving recordings with Vector or Matrix values likely won’t work.
For debugging layouts this can also be used together with the Simulation time slider add-on.
Intended workflow:
- Set up a layout with some inputs coming from external system using the Connectivity feature.
- Create a new empty recording and set the plugin to “Record IO” mode.
- Run the simulation at 1x speed along with the external system using the Connectivity feature.
- Reset simulation, optionally save the recording with the layout.
- Disconnect from any servers in Connectivity.
- Select the recording, set the plugin to “Replay IO” mode.
- Run the simulation slower or faster than realtime as you please.
- Optionally if used for “warmup”, you can connect to the external system once playback has finished.
Here is a Connectivity performance test / demo layout with 2 recordings. However, this particular layout doesn’t run much faster than realtime with IO playback because it is a stress test.
More realistic use cases should run the playback much faster.
Pixels demo with recording.vcmx (14.8 MB)
