All the necessary
components and layout
PLC program
Instruction file
attached hereby
All the necessary
attached hereby
Here are the attachments
Cool stuff, good job!
Here is updated files.
Are there any plans to implement a direct interface to connect Visual Components to Siemens TIA without the Kepware App?
Just a heads up, if you are using at least TIA Portal V14 or a S7-1510 CPU you are able to connect those to VC via OPC UA.
Greetings Felix
Hi Felix,
does TIA Portal V14 has an integrated OPC Server?
br/Ralle
Hey Ralle,
Yes, SoftPLC’s created by TIA Portal V14 can run OPC UA Servers. The same behaviour applies to S7-1510 CPU and above.
Greetz Felix
Hello Felx,
thanks for information. So it is similar to the integrated OPC UA Server in TwinCAT.
br/Ralle
Dear Sirs ,
I can’t establish this connection between simpro software and TIA Portal simulation
any help please ?
I have followed the steps with the demo version of KEPserverEx, and at first everything went right. However, every time I retry it, the connection variables is established from Simulation to Sever, however not from Server to Simulation.
What’s the problem ?
This software is for programming old Siemens drives including simovert series, masterdrive, micromaster and … This software is installed on windows xp, 7 32 and 64 bit.fixborad
