Hi, I am running an async OPC UA server on Python which I am trying to connect to Visual Components. However, I’m getting an error which doesn’t allow me to connect to the server for some reason.
Here is the code:
> /usr/bin/env python3
> # This file contains a set of classes and methods to handle
> # running a OPC UA server on a raspberry pi.
> import asyncio
> import random
> import time
> from asyncua import ua, uamethod, Server, Client
> import announce_service as sa
> SERVER_NAME = "RaspPI OPC UA Server"
> FLAT_NAME = SERVER_NAME.replace(" ", "")
> SERVER_PORT = 9000
> SERVER_ENDPOINT = "opc.tcp://0.0.0.0:"+str(SERVER_PORT)
> UA_NAMESPACE = "hvproj:ua:"+FLAT_NAME
> DISCOVERY_NAME="_"+FLAT_NAME[:10]+"."
> TEMP = 19
> class SubHandler():
> Subscription Handler. To receive events from server for a subscription
> data_change and event methods are called directly from receiving thread.
> Do not do expensive, slow or network operation there. Create another
> thread if you need to do such a thing
> def datachange_notification(self, node, val, data):
> print("Python: New data change event", node, val)
> def event_notification(self, event):
> print("Python: New event", event)
> client = None
> handler = SubHandler()
> sub = None
> handle = None
> class ServerPI:
> def __init__(self):
> self.temp = TEMP
> self.clients = {}
> # This ua method is used to subscribe to a variable on
> # another server.
> # Inputs:
> # endpoint(Server url as string): the path to server to subscribe from.
> # qx(NodeId in string format): The variable to subscribe to
> # ix(NodeId in string fromat): The variable to connect subscription to
> # Returns void.
> @uamethod
> async def subscribe(self, parent, endpoint, qx, ix):
> server = str(endpoint)
> if server not in self.clients:
> try:
> client = Client(server)
> await client.connect()
> await client.load_data_type_definitions()
> self.clients[server] = (client,set())
> except:
> return "Could not reach the server specified."
> else:
> client = self.clients[server][0]
> #root = client.get_root_node(
> #uri = "http://examples.freeopcua.github.io"
> #idx = client.get_namespace_index(uri)
> qxvar = client.get_node(qx)
> if qx not in self.clients[server][1]:
> self.clients[server][1].add(qx)
> print(len(self.clients[server][1]))
> sub = await client.create_subscription(50, handler)
> handle = await sub.subscribe_data_change(qxvar)
> time.sleep(0.1)
> return "Successfully subscribed to the specified variable!"
> def method_var(self, name, description):
> arg = ua.Argument()
> arg.Name = name
> arg.DataType = ua.NodeId(ua.ObjectIds.Int64) #NodeId, and not datatype of value. We use Int64 ID's.
> arg.ValueRank = -1
> arg.ArrayDimensions = []
> arg.Description = ua.LocalizedText(description)
> return arg
> async def go(self):
> server = Server()
> await server.init()
> server.set_endpoint(SERVER_ENDPOINT)
> server.set_server_name(SERVER_NAME)
> server.set_security_policy([
> ua.SecurityPolicyType.NoSecurity,
> ua.SecurityPolicyType.Basic256Sha256_SignAndEncrypt,
> idx = await server.register_namespace(UA_NAMESPACE)
> objects = server.nodes.objects
> #dev = await server.nodes.base_object_type.add_object_type(idx, FLAT_NAME)
> lFolder = await objects.add_folder(idx, "Sensors")
> print("Sensors folder: ", lFolder)
> zobj = await objects.add_object(idx, "Methods")
> print("Methods object:", zobj)
> zvar = await lFolder.add_variable(idx, "ixTemperature", self.temp)
> print("Temp var: ", zvar)
> endp = self.method_var("Endpoint", "Address to tendpoint")
> qxvar = self.method_var("qx", "Output variable to connect to server.")
> ixvar = self.method_var("ix", "Input variable that is to be connected to.")
> ret = self.method_var("ret", "Return message for information of what happend.")
> await zobj.add_method(idx, "subscribe", self.subscribe, [endp, qxvar, ixvar], [ret])
> async with server:
> while True:
> await asyncio.sleep(0.1)
> await zvar.write_value(self.temp)
> self.temp = 19 + random.random()
> if __name__ == "__main__":
> print(DISCOVERY_NAME)
> sa.start_service_announcement(device_name=DISCOVERY_NAME, iport=SERVER_PORT)
> sp = ServerPI()
> asyncio.run(sp.go())
Now if I change to a regular OPC UA Server the connection actually works. But with an async server it doesn’t? I don’t understand what the issue is here
Error message:
Connection failed.
Following error and warning message(s) were received from the Connection Plugin:
[ERROR] Failed to load endpoint descriptions from the server and select one that matches the specified security and protocol criteria.
[ERROR] Connecting to server failed: An unexpected error occurred while connecting to the server.
