When I installed Blender from the link at the start of this thread, the link directed me to the windows store and it installed the software in the windowsApps folder in Program Files. This folder is hidden and needs higher permission to allow VC to access it.
I then downloaded the Blender installation file directly from Blender at Download — blender.org and it allowed me to select its own installation location. This worked perfectly with no issues.
hey there Radovan,
Did you solve this issue?
I’m trying to use Blender on Kuka.Sim but I’m having some errors when I run the simulation. So I thought you could lead me the way to solve it
Thank you
Hey guys,
I’d like to use Blender on KUKA.SIM. I installed and added the Blenderer addon without any issues.
I followed this path:
*** Error in animation rendering call. ***
- Make sure you first check "RecAnimation" check box
- Then run simulation once until "RecAnimation" is automatically unchecked
- Then hit "RenderAnimation"
I got these errors when I followed the path:
File "file:///C:\Users\%users%\Documents\KUKA\KUKA Sim 3.1\My Commands\Blenderer_2_3_0__2023_09_14\Blenderer.py::", line 839, in CallStill
File "file:///C:\Users\%users%\Documents\KUKA\KUKA Sim 3.1\My Commands\Blenderer_2_3_0__2023_09_14\Blenderer.py::", line 992, in CallBlender
File "file:///C:\Users\%users%\Documents\KUKA\KUKA Sim 3.1\My Commands\Blenderer_2_3_0__2023_09_14\Blenderer.py::", line 968, in get_blender_exe_uri
TypeError: an integer is required
Do I need to change the code inside the Blenderer.py file or what?
Hello everyone!
I am currently using blender to conduct some pipeline experiments. I found that in some of my files, the robot is working very normally, while in other files, my robot is twitching strangely as if it was invaded by a cyberpunk virus .Although the overall operation is still very good, this twitching still affects the look and feel a bit. What is the reason for this, and is there a way to eradicate it?
Thanks in advance to anyone who responds and have a great day!
I checked my model again and found that this problem only occurs with robots. I suspect it is because of the robot IK. At the same time,I found that this problem does not appear in blender plugin version 21, so it seems that this is an overlooked optimization point in the new version of blender plugin.
This problem does not seem to be a problem with the plug-in itself. Most of the time, the problem should be caused by not correctly assigning the Blender address to the plug-in, something similar to this:
I would say this is not an error, it’s kind of reminder, Blender add-on needs to get camera moving path and components positions first, then create video frame by frame, so you need to
Check Animation::RecAnimation: Tell Blender add-on that you want to record a video.
Run simulation: Let Blender add-on to get camera moving path and components positions.
When Animation::RecAnimation option is unchecked by Blender add-ons itself, not manually, which means simulation time is bigger than Animation::EndTime, Blender add-on has got enough information, press Animation::RenderAnimation button to start create video.
Hello, could someone possibly help me? I use blender mainly for pictures, but I don’t understand that they are sometimes so overlit and sometimes perfect in quality only if I change the view a little.
Especially the floor bothers me that it is not rendered in detail.
Here is an example where the same settings were used.
Mainly i get the bad ones thats so frustrating.
