I’m trying to make a simulation on KUKASIM 4.0, I try to aling a block to make it match with 2 points on space but I can’t.
I attach an Image to illustrate the situation:
The distance between the points is 2319.3 mm
Then I add the block with the same dimension as the distance betwen the points: 2319.3mm
I attach the edge of the block to the first point. The block situates in the desired position.
Now I want to rotate the block with the edge 2 to the point 2 (but I want Point 1 remain on the first point position).
All the times i want to make that maneuver… the block is positioned in the point 2… but moving the point 1.
And if I try to do it by hand rotating the block i can place it but not precisely.
So, how can I do this maneuver?
Thanks in advance.
