I search for a solution to make my components, i don’t want to see, invisible by rigthklicking.
Is there a possibility to make an Add.On or a command, where i can set the Visibility to False only by rigthklicking and select a command.
Would be nice if someone can help me with my problem :).
This is certainly possible, but before that, since you have already selected the geometry, why not use the visibility in the properties to directly manipulate it?
yeah, i do it that way, but i want to be faster while simulate and i want to keep my distance with the mouse very short:) Thank you for your message, can you help me with my problem?
Hey, sorry to ask you again, but i downloaded your Plugin and unziped it to …Visual Components/4.7.My Commands and it didn’t work. Did i something wrong?
