Probably easiest way to achieve this is to use the Blender add-on to export an animation from VC to Blender where you can then render the 360 degree videos.
To do it directly from VC you would need to write a .NET plugin that renders the scene 6 times to get each face of a cubemap and use some external software to stitch them into a 3D video.
Thank you very much! Blender worked for creating both 360 images and 360 videos. For videos, the rendering process takes a while and requires a few extra steps (downloading python and a spatial media injector). All of this is free and I was able to accomplish my goal, but I would still love to see this integrated directly in visual components as an option or add on…it would be so cool!
In order to create 360 content, you must open the project in blender. This is done by checking this box in the image below, then selecting “render” in the default tab. Once your model is open in blender, you must follow the steps in the video posted by TSy above. Hope this helps.
The tuto is good and after that the video is converted in 360 but I don’t know it’s the same for all but when I used injection Software to convert my video the software convert this but after my video is deformated.
Yes it’s probably this but in tuto he sayed to change the view to panoramic and after the type in equirectangular when you select the camera but in my version of blender I don’t see this option after the changement of view.
After that I realize the render of images.
I don’t know if it’s an reason but Youtube recommand to create a 360 video with resolution 7610x3584 and for this reason before the start of simulation in Visual Components I modify the parameters of resolution to 7160x3584.
Do you have an idea to resolve this please ?
If you want I have the project blender.
@Deros your settings are incorrect. You need to use the “Cycles” rendering engine to change the panorama type to “equirectangular”. The aspect ratio just needs to be twice as wide as it is tall.
Ah ok ok thanks because when I search this functionality I don’t find them.
I think it’s good I change the render engine to Cycles and the type of panorama to Equirectangular now.
I start my render of my differents pictures to create my animation after.
I’ll keep you posted and let you know if it works.
