How do I display the wrapping cover after the product is wrapped?
You can attach a clear box on top of the product to kind of visualise a clear packing.
There are some components in the Packaging file of the eCatalog to wrap products and some examples of wraps you could use.
Could you please suggest, I need after the product get wrapped,
Can you please tell how to visible wrapped product?
I need final product get wrapped
You can use the method Este suggested: define the plastic wrap as a new Product, and use the Attach statement to attach it to your product getting wrapped.
Otherwise you can use the components of the “Packaging” file in the eCat to wrap products, they will do it automatically when used correctly.
Or if you have access to the Modeling tab, you can have the product and it’s wrap as one product, and add a property and a switch feature to be able to turn it on or off with an Assign statement in your process. You can have a look at the component “Plastic Food Pack” under Products and Containers in the eCat.
Thanks for sharing the information. We’re looking to implement a model that can wrap products after processing for our model, similar to stretch wrapping and box wrapping machines. Can you support us in developing this model?
