Hello everyone,
is it possible to have a Works Process with multiple inputs (3 in my case) but only one output. It should look like this:
Thanks in advance!
Hello everyone,
Thanks in advance!
Hi JacobHerk,
That’s possible, but requires quite a lot of editing in the works process, paths, proxy and code editing…
If you’re not intending to interact with any resources in the process (e.g. Feed, Need) then I’d consider using totally another approach instead of using Works Process. That is just an inline process.
It’s quite difficult to give more precise guidelines without knowing the actual purpose of that setup and what’s happening in the “process”. One thing is for sure that you need one Path and associated Interface for each input and output.
