Hello, guys
Today I’ve updated my VC to 4.5 and found out that i miss works library and its elements in my eCatalog.
Could you please advice me what’s wrong? Maybe you renamed it and i didn’t notice it in the changelog ![]()
Thanks in advance!
Hello, guys
Thanks in advance!
I think it has been deprecated, as Process Modeling does almost all of it better these days.
You can still enable visibility of the legacy libraries from the “Edit sources” dialog.
Thanks for a reply.
I just tried it again after installation of 4.4 packages.
I used a simple example: works process + create command, but i was getting following error (see output):
Nevertheless, old layouts that I did in VC 4.4 are still working well in VC 4.5
may try insert the TaskControl-Component?! ![]()
Ah, true, forgot it.
Thanks, now everything works fine!
