,How to use “IF” correctly in workProcess, The Feed should only be executed once in this program, and then just keep running transportIn transportOut. But the results are wrong
I think it might be better to use a Warmup instead.
In the warmup, you have the special case with Feed. After the warmup, you have the normal tasks.
thanks for your help ,it works
