I want to delay the work item creation in ‘Works Process’ item from library. Is it possible to do?
What do you mean by “work item”?
It’s a entity or we can say it’s a variant (Child part) for my assembly process which get assembled with other variants. At the start of assembly process, I am creating one variant which I want to create with some interval. I am creating this variant at Works process.
A Delay task can be used. Another option is a Loop task. Might be others, but those two task types can be used to create parts at intervals
Hello Zesty,
<p style=“text-align: left;”>Thanks for the Positive and quick response. Yes, that delay command is working but I am not aware how to use loop command. It will be very helpful if you suggest any example for loop command.</p>
Thanks for the Solution Zesty.
