i tried using Oculus Quest as my Headset but it does not connect to the VC Experience
^combining these threads
Howdy. Any device that is compatible with Steam VR is supported, so you most likely need to troubleshoot the connection of Quest and Steam VR.
In terms of best device, I would say best is what works for your needs. For example, if a wireless device is more important than go with that, otherwise device with cable connection is okay. Generally, VC Experience is tested with HTC Vive.
Could you explain more how i can run vcax or vcmx file in Oculus Quest?
I tried with HTC Vive and it work. I install VC experience into my computer and run the VR from it.
But for the Oculus Quest, I could not find VC Experience app in Oculus Meta Quest store. So i wonder how can i run the file?
Thank you for your support!
You need to use the Oculus Link to connect the headset to the PC to have it work.
Is there any tutorial video or documentation on using VR? I also want to buy a VR headset.
