Dear Sir/Madam,
Recently, I want to use Visual Components
software with VR function, but I do not know how to setup it. Do you have any
tutorial? Thank you very much.
Best regards,
Dear Sir/Madam,
Best regards,
Hi, I have the same problem,
it seems very difficult to configure the VR headset to work with the Visual Componet Experience
I tried to look for something but it’s all very confusing.
Perhaps VC has to work a little on this subject
Best regards
Francesco
Have you checked the VC Experience user guide? You should have setup instructions in there.
You can find the document from the VC Experience website at: Visual Components Experience - Visual Components
Ciao Este
Yes I had tried several times to follow the guide, but I had not obtained positive results.
Now I try again by resetting everything, let’s see if starting from scratch I can somehow solve it.
Thanks anyway for your suggestion
