VR Interaction is not working
Hi there,
I was trying to create a showcase for VR in Visual Components where I just start a machine in VR and make some grabable products.
I added the device controller v2 but when I jump into VR via Experience, the device controller component gets not tracked with my VR controller so I cannot do anything besided teleporting and measuring.
It seems that I am not getting any DeviceInputs, the dictionary suppost to be stored in DeviceInputs is empty. All other properties in VREvents like, DeviceModel, ClientID and so on works fine.
Did I do something wrong or does anyone has the same problem?
Using Premium 4.8 and Experience 1.7.
Thanks!
The interactive VR requires animation streaming in VC Premium. It does not work with pre-recorded animation files.
https://help.visualcomponents.com/4.8/Premium/en/English/Export/Streaming_animation.htm
So make sure that you are live-streaming the simulation and then the interactions should start to work. See these Academy tutorials for reference:
If you are already using animation streaming, then I think it’s best to contact VC support and inform them on what kind of VR setup you are using.
