Is it possible to make an order for the pickable objectives so that you cant place part 2 before you have placed part 1?
Is there also possibility to adjust the range when the part attachs to the blue area where it shows the defined place. Now the part attachs to the blue assembly location when the part just touches it.
The program doesn’t show all parts assembly locations as a blue when you pick the part and shows them the same as the part is. Any fix to that?
