Hi everyone,
I’m working on a measurement strategy using a Renishaw sensor in KUKA Sim (which should behave the same as Visual Components).
To implement this, I created a Volume Sensor in the model and connected it to a Boolean signal. For testing purposes, I used a Python script to print a message when the volume collides with another component in the cell — and that works fine.
When I load the cell with the robot and manually add the sensor tool into the cell, everything still works correctly.
However, once I attach the sensor tool to the robot as a tool, the Volume Sensor stops working — even if I detach it again afterwards. No collisions are detected anymore, and the Boolean signal doesn’t update.
Could it be that something is overwritten in the component when the tool is attached to the robot?
Has anyone experienced something similar or knows what could be causing this behavior?
Thanks in advance!
