Visualization component file that cannot run smoothly
Could someone help take a look?
I can not run Visualization component file smoothly.
We have some robot program in the software(VC primium 4.7).
I assumed that if I tapped the play button, the robots can run smoothly. But actually I tap the play button, but it just run nearly 1s and stopped, one robot arm will turn red ,like the picture shows.
but it’s strange that the file can be run smothly in my colleage’s computer.
Has anyone encountered a similar problem?
If you have any suggestions, please let me know.
Thank you very much!
You probably have a collision detector active that stops the simulation when robot has a problem.
Check the top toolbar in the Program tab, and see if the collision detector is active. Alternatively the problem could be joint limits or similar, so see the checkboxes.
The Output panel at the bottom should have a warning message telling you why did the simulation stop.
Yes,you’re right. It can run smoothly now.
