If there is a need to update all or many components which reside in one folder then this Add-On can be used as a base to update all of those components with one button click. User needs to modify the script as per his own requirement(what common changes he wants to do all those components) but this Add-On provides a good base for not to worry about setting up the little bit complex URL settings.
Note : Add-On is attached in the following (see below).
-Sicario
component-update-script.zip (748 KB)
