Has anyone had any experience of using RoboTeam with KUKA robots in Premium 4.6 with KUKA OLP enabled?
We’ve followed the instructions in the KUKA Programming Help file and can jog the robots in simultaneous motion but when we come to program them, we cannot access the specific RoboTeam commands in the Logic section of the programming tab.
Even if we ignore the RoboTeam commands and use simple jogged motions, we receive an error saying that the BaseFrame is not connected to the flange node of the master robot. We know that it is as we can move the master robot and the slave moves with it.
RoboTeam test.vcmx (4.3 MB)
This is our test file, any help on it would be great!
We cannot access the specific RoboTeam commands in the Logic section of the programming tab.
-Did you add the optional packages to both robots?
-As said in the output panel, Robot frame BASE_DATA[1] is not attached to KR 120 R2700-2 #2 (mountplate).
For the Base[1] of the slave robot (KR 120 R2700-2), you have to attach to the Node to the KR 120 R2700-2 #2::mountplate and not the KR 120 R2700-2 #2::A6
We’ve corrected the second error and that message has disappeared but we still can’t get the RoboTeam commands to become available; they look like this on both robots.
We’re not sure where we add the RoboTeam option to the robots as the network mapping suggests that they are in one RoboTeam network and we can jog the robots in co-ordinated motion.
For others running into this problem, it could be that the project is named “roboteam test” with a space and you are not allowed to name your project after a KUKA option package. It should give you a warning with this statement when loading the project.
I also encountered the problem with Unhandled exception on starting the simulation. Robot frame BASE_DATA[1] is not attached to KR 10 R1100-2 (mountplate).
The KUKA manual on this is wrong, as it states Select axis 6 of the master robot for the Node parameter (e.g. for a KR 16-2 this is the entry KR 16-2::A6 ), where it should have been KR 16-2::mountplate
Keep in mind that there are still issues with the RoboTeam in Simulation.
Especially Geolinking two robots if working at all still yields different results.
The issue here is the underlying RCS module for the robot motions is very hard to keep in sync. because windows services are not good at deterministic timing…
The slide is from KUKA.Sim 4.3 where this has been introduced, which is essentially the same running in the KUKA AddOn
