has someone see this outputs after start of VC?
Thx & Regards
Thx & Regards
Hi, did you fix this?
Just getting the same now and would appreciate some advice if you have any.
Thanks!
could it be that there is a Bug in Human Transport Controller?
Those shaders are for rendering different material types and all are loaded when starting the application. The issue is likely some compatibility thing with your GPU and its drivers, so please try and install latest graphics card drivers. Also if you have both discrete and integrated GPU, set VC to to use the discrete one.
Thank you. For anyone looking at this in the future, the issue was indeed that Nvidia brought out an update and my graphics card driver had to be updated. All resolved after updating the driver. Much appreciated!
This was occurring straight away when opening the program. The solution was given by @TSy below but thanks for the suggestion!
