Hi
how to change the direction of a 2-way-path with python script ?
Thanks in advance
I have shared simple script to change direction of Two way path by using boolean signal
DirectionFwd → Boolean signal
conveyor_full - > Boolean signal
" conveyor_full let you detect when the part is left from the path . " If you don’t need to monitor parts on conveyor you can delete OnPhysicalTransition event
def OnSignal( signal ):
global path,conv_direction
if signal.Name == “DirectionFwd” and signal.Value == True:
path.Enabled = False
path.Direction = VC_PATH_FORWARD
path.Enabled = True
elif signal.Name ==“DirectionFwd” and signal.Value == False:
path.Direction = VC_PATH_BACKWARD
path.Enabled = True
pass
def OnStart():
global path
path.Direction = VC_PATH_FORWARD_AUTO
def trans(cont, _part, arrive):
global part, conv_full
if arrive:
part= _part
conv_full.signal(True)
elif arrive ==False:
part = None
conv_full.signal(False)
comp= getComponent()
path = comp.findBehaviour(“TwoWayPath”)
conv_full= comp.findBehaviour(“conveyor_full”)
path.OnPhysicalTransition = trans
Thank you very much !!!
