Hi all,
I’m running KukaSim Pro 3.0.4 and OfficeLite 8.3.32 on Win 10 and the connection between the two softs works fine. But when I start the simulation by clicking on KukaSim which normally makes the program start also on officelite, the simulation doesn’t start ans I have a big error list that I post below.
I’ve already re-install KukaSim and it does the same thing. I think this a windows problem or something missing in visual Components installation. Does anyone have an idea to help me? Thank you
Unhandled exception occurred:System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at VisualComponents.UX.Krc.KrcController.InitializeIos()
at VisualComponents.UX.Krc.KrcController.SimulationStarted(Object sender, EventArgs e)
at VisualComponents.Revolution.RobotExecutorWrapper.raise_SimulationStarted(Object value0, EventArgs value1)
at VisualComponents.Revolution.RobotExecutorWrapper.OnSimulationStartStop(Boolean started)
at rTCmdEventWrapper1<bool>.Signal(rTCmdEventWrapper1<bool>* , Boolean a)
at rTObjConnection1<rTCmdEventWrapper1<bool>,bool>.OnSignal(rTObjConnection1<rTCmdEventWrapper1<bool>,bool>* )
at rSimulation.Run(rSimulation* , Double )
at VisualComponents.Revolution.SimulationWrapper.Run(Double time)
at VisualComponents.Create3D.SimulationService.RunSimulation()
at VisualComponents.Create3D.SimulationService.SwitchRunState(Double runTime, Double warmUpTime)
at VisualComponents.UX.Shared.SimulationControlViewModel.SwitchRunState()
at VisualComponents.UX.Shell.AppBootstrapper.OnInvokeAction(ActionExecutionContext context)
at Caliburn.Micro.ActionMessage.Invoke(Object eventArgs)
at System.Windows.Interactivity.TriggerBase.InvokeActions(Object parameter)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.Controls.Primitives.ButtonBase.OnClick()
at System.Windows.Controls.Button.OnClick()
at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
at System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
