Hi
I’m using a robot with Process Machine - Work Table
When my product is detected by the sensor on the conveyor, the robot take the product to the machine
I’m using Program function for the robot movement (not Process function)
My problem is when the product is in the machine , the “TransportIn:Any Product as Product in” is not detected.
If you have a solution please help me.
Robot_Programtemp.vcmx (4.6 MB)
DIdn’t check your file, but the TransportIn must be set to “From Component Container” mode, and the robot must place the product into a correct component container.
Dear TSy,
I test it as you tell me but it doesn’t work.
