I’m new to visual components and want to transport multiple pallets to the ASRS at once.
Even if I change crane’s capacity, Crane can only carry one pallet a time.
Specifically, there are multiple pallets in ASRS-Infeeder, and a lifter transports the pallets at once and stores them in different racks.Even when leaving the ASRS, the lifter carries multiple pallets and carries them to the ASRS-Outfeeder.
If all of your pallets are in the same process station you can follow the steps.
Create a dummy component.
Attach all your pallets to that dummy comp.
Transport dummy component.
Also if you check ‘Palletizing layout with truckload forming’ layout from demo layouts. This method is used at the end truck forming transport out part.
