Is there a routing rule that allows you to only transfer a box/tote down an off conveyor when it has been to a certain location in the model and if it has not been to that location, it does not get transferred?
I am not sure if I understood it correctly.
At your specific location in the model you can use the “Property Setting Point” component on a conveyor to change the value of a properties
or (if using process modeling) you can change the value of property with the assign-statement in a process routine.
You can use the string rule (or the others rules, depends which property), for more see about routing rules video on academy:
