Transfer Visual Component Line layout to .dwg or .dxf
Hello VC Friends, I try to export visual components top view layout to .dwg and .dxf file , for our IE use AutoCAD to measure the dimension. Since we design a large factory layout in visual components (most import from Solidworks) that makes the layout so big(413M in Visual components), it takes 10minutes to transfer to .dwg/.dxf file(13G in .dxf/dwg). It spent 5 minutes through AutoCAD , still rolling and can’t open.
Any friends have good idea , for quick transfer to .dwg/.dxf (in 3D Top View) and easy open in AutoCAD?
413MB in VC is really huge! → A lot of stuff means a lot of lines means more time to collect them!
May you make a little clean up?
