I’m currently trying to implement an industry 4.0 solution with parts being modified in machines according to a configuration beforehand. These cubes start from the same sample from a feeder and should go through 3 stations changing their appearance. So now I need some way to track those different cubes so every station knows what modification to apply to them (eg. conveyor diverter).
While researching I discovered ProdID but as far as I can see, those are all given to the same type of cube instead of a new one for each new product.
You can then with just process statements start building up your if-elseif-else tree when you have grabbed the ID and change it accordingly. Figure 3 shows this.
Figure 3, notice the notation to grab ProductID → ProductIn.Component.ProductID
