Paul
March 28, 2026, 6:31am
1
Hi everyone
I’m quite new here and currently trying to model a simple toolchanger with the UR5e.
So far I had my tools both working but the TCP for my Tool2 was off. When I changed it to grip a cube I suddenly cannot change to my tool1 anymore.
Any help appreciated!
TestSim.vcmx (303.0 KB)
Tilma
March 30, 2026, 3:32pm
2
Hi, what doesn’t work exactly?
I tried DismountVac, MountGripper, DismountGripper, MountVac and they all worked
Paul
April 1, 2026, 4:48am
3
Hi, thank you for your reply!
For me the “MountGripper” didn’t work. The robot would move to the position of the gripper but didn’t pick it up and just waited indefinitely for the “Gripper Closed” signal.
I’ll try again to see if it was just a bug and let you know!
Paul
4
Just tested it: For me it doesn’t work correctly https://youtu.be/IrUEFIfWy9Y
I have reviewed your example. When installing the new tool, the original tool needs to be removed. In your case, you merely hid the original tool.
Tilma
April 1, 2026, 6:46am
6
as Alexander said, the robot can’t grasp 2 tools on the same interface. When I tried I used the DismountVac before the MountGripper routine
Paul
April 1, 2026, 6:58am
7
Ohhh now I get it. The robot doesn’t automatically dismount when you reset the simulation?
Thank you!
Resetting the simulation will return to the state before the simulation began. For example: Before the simulation started, the robot had tool A installed. During the operation, tool B was replaced. After resetting the simulation, it will revert to the state where tool A was already installed.
Paul
April 1, 2026, 7:31am
9
Okay jep, that’s what I was thinking previously.
Now I know where my mistake was - thank you very much everyone!
Kwon
April 3, 2026, 5:00am
10
Hello.
Please review the attached example file.
I have configured the generated gripper to be attached.
Gripper_Example.vcmx (275.7 KB)
Paul
April 3, 2026, 8:46am
11
Thank you! It is working now
Is there a way to mark the question solved?
Kwon
April 3, 2026, 10:12am
12
As far as I know, there is no separate way to mark the issue as resolved.
I am glad to hear that the information was helpful.
