To explain the problem I’m facing this is my simplified setup:
The robots picks parts from a feeder and places them onto a conveyor (standard ToConveyor proces).
However, the problem is that the next time I open the simulation model, it goes back to placing the products in the default position and orientation.
Seeing I have multiple of these positions in my actual model, changing them everytime is very tedious.
Does anyone know how to permanently set this position and orientation?
In the TransportIn statement you can select which frame to use for the product position. You could add your own frame feature and use that in the statement to see if it makes a difference. I think there is also a Python command somewhere to create frames into components so you don’t even need to do it from the modeling tab.
If I recall, some of those PM flow components have component properties and scripts to define the frame positions from the properties panel, so the actual frame feature’s position is overridden. This might be why the the modified frame position gets lost.
