There are two parallel processes B and C under process A; How can the first product flow into the B process and the third product flow into the C proces
Ummm, if you are talking about the indexing feeder, it can be found in the “Bottle Filling Layout” of eCatalog. ![]()
I’m not sure what you mean, but the GetFlowStep and SetNextFlowStep might be a solution
Example_SetNextFlowStep.vcmx (287.5 KB)
Thank you for your solution. The problem I encountered can be solved by your method.
Thank you as well.Tilma provides a suitable solution
Hello, How to realize that one out of every 10 products flows into B process, and the rest not divisible by 10 flows into C process?
if you want that each 10th product out of 10 flows into process B, you can use a modulo function :
If you want to have it a bit more random, like 10% of the products flow to B, you could use a uniform function:
You can find more informations about the functions in the Help File → Expressions → Functions
Thank you very much for your careful guidance!
