Text in 3D PDF
Hi!
This work horse that can show text in 3D pdfs as well as in VC animations (.vcax), supports now plain backslash, and a dot and a hyphen.
Type \n for line break and \t for tab (if you don’t like hitting the space):
Enjoy and stay tuned!
P.S Relaunch VC to refresh your eCat. Right click context menu “Refresh” might come handy as well!
Hello, i’m trying to use this to display component properties value in simulation, for example Value of Analog Clock to display cycle times… but it always shows just UserDefinedString TypeMe property…
Hi @jouha,
I am having the same UserDefinedString issue. Any update or fix?
Thanks.
Hi @12grahamb,
The component may not work properly in VC Essentials, in case you are using one. The Professional is then required at least.
Otherwise, just make sure all of the properties are setup when using the “ComponentPropertyValue” TextMode:
