Can I use teach Position to set the material position instead of setting its value,
Because I can’t align the parent object
You need to create a frame feature and assign it as the ProductPositionFrame.
Thank you, I have another question,do you know how to write your own program to make the robot carry the box, I tried this but it didn’t work
Please refer to this manual:
look in the document Tsy has shared with you on page 18. → That’s what you need!
I can’t download your example…
But I think with the document you should be able to learn and fix it!
Amazing, I don’t see any change in Settings, but it works fine
I have done this by using the things from the academy document on page 18!
